V̶a̶n̶i̶l̶l̶a̶T̶w̶e̶a̶k̶s ✨ TeamSpeak Tweaks
TeamSpeak ≥5 Theme Generator
TL;DR: TeamSpeak Theme Generator
Tired of static themes that don’t quite match your vision? With our innovative theme generator, you’re in full control. Choose exactly the features and design elements you need, and create your custom theme in just a few clicks. Customization has never been easier—get everything you want, exactly the way you envision it!
Jokes aside - I created a Vanilla Tweaks inspired theme generator for TeamSpeak ≥5. It allows you to select the changes you want your theme to make.
:rocket: Usage
Simply open the Theme Generator, select the components you like, press the export button, and extract the zip to the correct folder.
You can sinply find the folder through the TeamSpeak client. Simply open the settings and go to AppearanceUser Theme🗀.
Default Path per OS
Windows
%appdata%\TeamSpeak\Default\extensions
Linux
~/.config/TeamSpeak/Default/extensions
Mac
~/Library/Preferences/TeamSpeak/Default/extensions
Then you can just enable the theme in the TeamSpeak settings.
:person_tipping_hand: Contributing
If you have any ideas or finished components feel free to open an issue or create a pull request.
If you like the project, consider leaving a :star: on GitHub!
There might also be an ad remover in there :thinking:
This works perfectly thanks! I liked the top theme :wink:
Great job Julian!
Strong work Julian!
Great job Julian! Thats amazing :100:
Cool site :+1:
@Gamer92000 Maybe you will find it useful for depicting themes
custom
Don’t you like my cool custom image? :scream:
I will certainly look into changing it, I just feel like the blue might clash with the client, will need to test it. Thanks though!
Like why) I just suggested it might come in handy. I can change the colors if you want
I’ll add more options
