serversnapshotdeploy [-mapping] [-keepfiles] [password=secret] virtualserver_snapshot
How can i pass fields like -mapping and -keepfiles for a http request?
From memory, something like:
serversnapshotdeploy?-mapping&-keepfiles
(etc)
Wait… what?? I have to update my parser… wouldn´t it be better to pass booleans?
I think the intent here was compatibility with the existing query methods.
@davinciTS Will it also understand serversnapshotdeploy?-mapping= ?
Edit: It understands -mapping=true
I wanna use WebQuery with docker, but i got no idea how to start. A small introduction would be nice.
Sure, you can do that. Set TS3SERVER_QUERY_PROTOCOLS (ie with -e) to include HTTP, something like (completely untested, just to get you started):
docker run -p 10080:10080 -e TS3SERVER_LICENSE=accept -e TS3SERVER_QUERY_PROTOCOLS=http teamspeak
Thanks for the quick help!
How do i generate an api key?
Do I need to generate it by my own? If so what’s the length/characters?
In ServerQuery you perform the apikeyadd command to generate one or you start a server for the first time.
Send command help apikeyadd to get more details about the usage.
Thanks again
How do I communicate on docker with ./ts3server ?
I’m not quite sure what you mean, sorry - what are you trying to do?
Hmm, check the docker logs, make sure you enabled raw query too in the docker for your nc: -p 10011:10011 -p 10080:10080 -e TS3SERVER_QUERY_PROTOCOLS=http, raw … etc. Then put that api_key in the post request as FakE says.
Forgot the raw on TS3SERVER_QUERY_PROTOCOLS
thanks
Btw, could you please allow to pass the api key via query parameter? Then it would be easier to use the api via the browser. It is a bit annoying to pass it via the header. You should allow both ways. Header should be preferred over query, but for quick tinkering it would be nice.
You already can - api-key if my memory is correct (hope so, can’t check right now)
Edit: fixed, my memory was not right
I tried api_key, key and apikey.
Show me what you’re doing - something like a POST/GET on /1/channellist?api-key=myapikey should work fine.
Ok yes, with api-key it works
