WebQuery discussion/help (3.12.0 onwards)
Hey there,
how can i use the serverinfo command?
at the old query system, we first had to select the virtual server via the use command. This command is not supported via the web_api und the serverinfo command retruns the informations about the first server ever created on the host.
This is how you could do it.
http://IP:10080/1/serverinfo?api-key=xyz
Server must be selected (1 in my example) and user must own scope manage.
Hello to all,
I’d like to start a discussion about the HTTP interface in the latest versions of TeamSpeak 3 Server and especially about the clientlist command.
My need is the following: to get the list of users connected on a virtual server with the nickname, cid, clid, connection ip and uuid.
From an SSH connection it is possible to add the parameters -uid -ip etc. But how to do it using HTTP interface?
Thanks in advance,
Guillaume
Just add it with &- behind the API key
http://IP:10080/1/clientlist?api-key=XYZXYZXYZ&-country
https://IP:10443/1/clientlist?api-key=XYZXYZXYZ&-country&-ip
Hello there,
Thank you very much for your help! This format did not come to mind.
I just wanted to ask again, will this ever land in Teamspeak server? I am waiting forever for this :frowning:
I made a small Munin monitoring plugin that queries http://localhost:10080/1/clientlist every 5 minutes. After a week or two the web query always stops responding and queries result in a timeout, similar observations when using curl. I’m running the official Docker image, it starts working again after a container restart. I see no bans being recorded in the logs.
Has anyone observerd similar things?
Is there any way to get the ping of every client connected? All I have rn. is a average, however its not very practical for network monitoring, as if one client has a 0 or 1000 ping the whole average is becoming less useful.
