Is there a way to whisper to a channel?
I want to be able to whisper to multiple channels.
Thanks
Thanks
When i hit the âVâ key to speak, i get the following message
No whisper target found
Here is my current test server and configuration.
Hi, the Message âNo Whisper target foundâ occures if you donât have a valid target , âclientâ to whisper one.
I am not trying to whisper to a client. I am trying to whisper to an entire channel.
If i try to change the configuration a little, i get the same error. Also, red icons show up next to the desired channels.
It says no whisper target found because there are no other users in any channel.
If someone connects then you wonât get that error.
You canât whisper to a channel if there is no client in it.
ok, thank you
