please help
Could you share some more information?
Version 5.00-beta23 changed some hotkey stuff.
Since then most things should work.
So What exact client version are you running?
What is the desired hotkey?
i am using teamspeak 3 and i want the hotkey b
Ok, then 1st please move this post to TeamSpeak **3** client
And about your problem make sure the correct hotekey profile is selected.
In your bookmarks / after you are connected you can select the hotkey profile on the self tab I think (can’t check rn as I’m on mobile).
So either create the hotkey for the default profile or select the correct one.
