Can i run 2 clients on windows ??
You can start TeamSpeak with the option -nosingleinstance. This will allow you to have multiple instances running.
Watch out though! They will have the same configuration and changing one will affect the other one.
Yes you can, just create a shortcut and add the option “-nosingleinstance”
Edit: @Gamer92000 i guess i wasn’t fast enough
Thank you it works , but is it possible with 2 different config files ??
You need a second installation in a folder where the user has write access and select to store the config files in the installation directory during installation.
