3.6.2 Flatpak version does not start anymore
Flatpak version of Teamspeak updated today. It does not start anymore…
Tried removing userdata. But still does not start.
Running CachyOS latest updates.
Best regards
The Flatpaks are not officially maintained by TeamSpeak. However, I did just open a GitHub issue for this problem:
Great! Thanks! :slight_smile:
Until this is fixed, you should be able to downgrade the flatpak to the previous version by running
sudo flatpak update --commit=fcd16e4851c76f7b872d2d84172c53ded14e40b790844e1479a46de4c97db80f com.teamspeak.TeamSpeak3
And to prevent updates pin the downgraded version
flatpak mask com.teamspeak.TeamSpeak3
After it got fixed you can unmask it again to include it again in updates
flatpak mask --remove com.teamspeak.TeamSpeak3
Many thanks! This indeed fixed the problem! :slight_smile:
Best Regards
AMDyZaN
Btw, the problem has been resolved. You should be able to use the latest version again.
Yepp, the new update works. Thanks for info.
Best regards
