Anytime i download the 64 bit version, and i try to open TS, it keeps crashing. The 32bit works fine but i need the 64 bit to work because i need to run a plugin that is only compatible with the 64 bit. So if anyone has gotten their 64 bit version to work, please let me know
please try start parameter -safemode . This will disable plugins and the client may be usable again. Now you can remove 3rd party plugins and maybe the client won’t crash when you remove the parameter again.
On Windows make a right-click on the shortcut you usually would use to start the client and then select properties. Then add the parameter as shown.
