A temporary band-aid solution for screenshare audio until a proper way is implemented
I know screenshare audio for linux is going to be implemented but in the meanwhile a quick and experimental fix that just creates another empty audio capture alongside the mic capture that we can manually connect pipewire nodes to would go a long way
We’ll implement it once the capacity to work on Linux stream audio is available.
A janky workaround would waste time that could otherwise be used to reach the point where we have time earlier.
