So, my government blocks teamspeak somehow, it does not work without a VPN. That is not computer or router specific. It is blocked on my computer, on friends computer and on my phone using seperate 4G connection. Obviously using a vpn solves all issues. If anyone knows ‘what’ is being blocked, I like to know.
I have rented a VPS and I am using it to run openvpn and teamspeak server on it. I was using openvpn for other purposes and at the time teamspeak was not blocked. I did notice that even though I am running openvpn connect on windows, the client still shows my IP instead of the VPS IP. My guess is teamspeak client is seeing the teamspeak server as ‘local’ and not tunneling through openvpn to connect to it. Meaning I cannot connect to teamspeak.
To sum up, TS is blocked by ISP, rented a VPS and hosted openvpn and teamspeak server on it. Still blocked since openvpn and TS are both on the same server. Rented another vps and installed openvpn server on it, I can connect to the teamspeak server now but I am paying for 2 VPS’s.
Is there a simpler or cheaper option ?
Edit : I can connect to the same vps that is running teamspeak to access openvpn, squid http proxy, pptp vpn and ssh and … so I know that the vps IP is not blocked.
