About DDOS
I have been dealing with DDoS attacks for a long time. Is there a provider with High DDoS protection and High uptime rates that you can recommend to me?
Registed domain and use cloudflare.
Enable proxy on cloudflare.
I use ovh and linode (akamai), those got some nice ddos protection even for 5$ month servers.
Just close all unused ports using hosts ufw and also ubunutus ufw.
and you will have
yourdomain.com → cloudflare → origin server
I use this kind of for huge project of mine and my uptime is 99.999%
Yes, you can purchase a VPS from FastLayer They provide excellent L4 DDoS protection, which effectively safeguards against DDoS attacks. Their solution uses an asymmetric DDoS protection approach, which is quite different from the methods used by OVH, Arbor, Voxility, and others.
