Hello!
It would seem that my “Manage” tab has gone missing since the last update.
Anyone else had this issue? It’s impossible to create a new recovery key now, and i had to use the one i had
Would be nice if a new one was automatically generated after a correct key is provided on request, so we don’t have to remember (or forget) to create a new one manually.
Any help would be appreciated, i can’t even log out since the option was in the now-missing Manage tab.
@TS.ChrisR You are correct.
I tried editing profile picture and was immediately prompted to use a recovery key.
But there was now a new issue, even though i was providing the correct key, and received a success message, i would be prompted to provide a new key immediately after… this would loop infinitely.
I had to restore from local data, hopefully the new key won’t create any issues.
@Rikku i thought to do exactly so, but it seems my ts3 version was too old, probably the reason why i ran into trouble to begin with… I have updated and both seem to be running just right now!
