Both servers are in same IP-block (new and old) so cant understand how the connecting problem would be about on my settings.
Old server (now with IP 62.183.177.252):
PING accounting.teamspeak.com (51.89.9.102) 56(84) bytes of data.
5 packets transmitted, 5 received, 0% packet loss, time 4005ms
New server (62.183.177.254):
12 packets transmitted, 0 received, 100% packet loss, time 11252ms
Either your did not forward the ports to the right IP or firewall/router blocks the connection
OR Cloudflare has the new IP blocked or has problems with routing.
Dont have any FW or router that I should think about and the old server was using the same IP-address earlier. I just shutdown all services, changed IP-address and started the ts3 on new server with same IP that the hostname is binded.
Well I need to monitor this for a while what happens next. Feels just weird that I can ping those hosts from any other computer but not from this server that I’m running the TS3 server on.
