Hello, I bought a Teamspeak license for 2 virtual servers and I got a file when I try to activate the keys one of them is working on the first server and the other not working on the second server , So how can I activate them pls…
Hello, you cannot put the license on two servers. but on your TS server you can create two instances
That’s Means only on one Server…?
yes you need to buy only one machine is on TS server you can create two instances
I advise you to use the software https://yat.qa/ easier to manage a server and be able to create instances
