Hello, I accept that you want to remove the telnet, but please improve the command ./ts3server_startscript.sh start serveradmin_password =.
Today we can only change the password serveradmin.
We created our own C | DBID, The problem is that to change the password we can only do it by telnet the command ./ts3server_startscript.sh start serveradmin_password does not work with another C | DBID
cordially
What you mention here is not a Telnet command. It’s a start parameter and independent from Server/WebQuery. It just overwrites a value in the database.
At this point the password for own query login is auto generated and can only be changed (auto generate a new password) by updating the own login name.
Can not say if that will ever change, but will bring that on developers table.
Thanks, I know the Telnet command, clientsetserverquerylogin client_login_name = #
If telnet is no longer supported in the next version it would be good if the launch command (./ts3server_startscript.sh start serveradmin_password =) can modify the C | DBID
Dropping the support does not mean that we remove it.
You need to use SSH or the Webquery instead of using a Telnet connection. This is all that does change.
It would be nice if you can create your own service like YaTQA (Panel) Like on TS2
