Add sound notification for AFK, Mute Mic, & Mute buttons.
hum, there is already sounds for each of those options
@otoroot is right. Enable the following sounds in your notification settings:
Advanced view:
If you want the sounds to play even when the speaker is muted or during AFK status, you need to select the pin.
Oh. I see now @otoroot . @Cornelius I already had them enabled but I guess the sounds don’t play when you are not connected to a channel. Also, how did you change to Advanced view?
right click
