had to update the TS Server software yesterday, but no database connection is possible. Always get the error message that 127.0.0.1 is not available. But the problem is that 127.0.0.1 is nowhere in the configuration, but a different IP address. It worked before.
My start commando:
sh ./ts3server_startscript.sh start inifile=ts3server.ini
My INI-File:
machine_id=
default_voice_port=31337
voice_ip=0.0.0.0
licensepath=
filetransfer_port=30033
filetransfer_ip=0.0.0.0
query_port=10011
query_ip=0.0.0.0
query_ip_whitelist=query_ip_whitelist.txt
query_ip_blacklist=query_ip_blacklist.txt
dbplugin=ts3db_mariadb
dbpluginparameter=ts3db_mariadb.ini
dbsqlpath=sql/
dbsqlcreatepath=create_mariadb/
dbconnections=10
logpath=logs
logquerycommands=0
dbclientkeepdays=30
logappend=0
query_skipbruteforcecheck=0
INI-File ts3db_mariadb.ini
[config]
server=192.168.0.150
port=3306
username=username
password=hardPassword
database=teamspeak
I had tried it with ’ ’ and without some symbols.
SSH output:
> TeamSpeak 3 server started, for details please view the log file
> teamspeak@Teamspeak:~$ 2020-04-03 12:49:27.260288|CRITICAL|ServerLibPriv | |Server() unable to initialize database
Logs:
2020-04-03 12:49:27.257812|INFO |ServerLibPriv | |TeamSpeak 3 Server 3.12.1 (2020-03-27 10:38:47)
2020-04-03 12:49:27.258016|INFO |ServerLibPriv | |SystemInformation: Linux 4.15.17-1-pve #1 SMP PVE 4.15.17-9 (Wed, 9 May 2018 13:31:43 +0200) x86_64 Binary: 64bit
2020-04-03 12:49:27.258038|WARNING |ServerLibPriv | |The system locale is set to “C” this can cause unexpected behavior. We advice you to repair your locale!
2020-04-03 12:49:27.258051|INFO |ServerLibPriv | |Using hardware aes
2020-04-03 12:49:27.259163|INFO |DatabaseQuery | |dbPlugin name: MariaDB plugin, version 3, ©TeamSpeak Systems GmbH
2020-04-03 12:49:27.259212|INFO |DatabaseQuery | |dbPlugin version: 2
2020-04-03 12:49:27.260248|ERROR |DatabaseQuery | |Could not connect to mariadb server: Can’t connect to MySQL server on ‘127.0.0.1’ (107)
Thanks for your help.
