Hello, does TS3 provides a API for audio streaming in voice channel ?
Depending on what you mean by streaming you can probably hack something together by using the functions RP Soundboard uses, specifically playWaveFileHandle. GitHub - MGraefe/RP-Soundboard: Easy to use soundboard for Teamspeak 3
