2022-12-25T23:00:00Z
Bonjour
Est il prévu dans un avenir proche que l’on puissent mettre des balises sur les descriptions des salons comme sur le temspeak3 voir screenshot pour plus de détails.
BBcode is only partially supported by the TS5 client. Markdown is possible.
Normally that should work, you need to make sure that the color code also is properly closed with [/color]. It seems like TS3 doesn’t need the closing tag, but TS5 does need it.
