Other users’ mics sound terrible, and they also complain that my mic quality is terrible. The audio quality settings in the channel is 10. Notifications also sound bad.
Make sure the codec in the channel is set to Opus Voice.
Unfortunately, this does not seem to be the problem. I checked the settings on the channel and it is set to Opus Voice.
Hmm, can you take a ss with your channel options and post here?
