Audio Settings not Saving
My Audio Setting do not Save
Every time i connect to a Server my Audio keeps sending even without me talking
Speech detection is on but until i retoggle it i keeps sending Audio
But it wont save the changed settings
same for me
Same Problem using TeamSpeak 6.0.0-beta2 on Windows 11 Enterprise 24H2 (26100.2894).
Same issue for mac version: 6.0.0-beta2 buildnumber: 1737468425
I also tried to reset and delete every cache & config, but no luck there
fresh install but still same problem
Version: 6.0.0-beta2
Build Number:1737468425
Chromium Version:130.0.6723.117
I had the same version since the latest TS5 beta (so 5+ months) and its sadly not fixed yet.
Build Number: 1737468425
Build Date: 1/21/2025, 3:07:05 PM
Chromium Version: 130.0.6723.117
OS: Latest Arch Linux KDE 6 (from AUR)
Workaround possible:
Microphone VAD settings do get saved, until you open the Settings > Audio page in TS6 again, by doing the following:
  1. Make sure you have the correct microphone already selected.
  2. Disable VAD.
  3. Set VAD mode to Automatic in dropdown.
  4. Set VAD mode to Hybrid.
  5. Set the desired threshold levels.
  6. Once done. Go to another settings page, to avoid opening Audio settings again when clicking on settings.
  7. The settings should now stay until the next restart, unless you open the Audio-Settings page again.
Today i noticed that the Problem is only there while using VoiceMetter Banana for Audio Routing
