Auto-Deletion of Users with no group but client rights
I know that the TeamSpeak Server deletes clients with no group (i.e. the guest group) after some time (in my case it was exactly one month). This is normal and expected.
But it seems that the TeamSpeak Server also deletes clients out of the database if they had client rights set and even a query login (which gets deleted too). In my case I connected with a new identity “serverlist_client”, gave it some client permissions to list groups, etc. and created a query login for that user. Exactly one month later, the client was deleted and the query login too.
I fixed this by recreating the user and giving it some random group this time, but I still think that it is unexpected behavior that even clients with set permissions are cleared from the database (as long as they are in no group).
Kind regards
What you did with your user is an edge case.
User hadn’t permanent group and did not join the server for x days as a client.
When this decision was made we thought about which users should be removed.
Decided was any user matching x days and got no permanent server group. Because a user who has no group can not be that important and when he did not visit for x days he is not that active or interested to stay.
Edit with important I didn’t mean that users aren’t important. But Admins or Mods did not give enough love to them :heart_eyes:
Ok, so in the future I’ll give my query login identities more love and add them to permanent groups :sweat_smile:
EXACTLY :smiling_face_with_three_hearts:
I’ve noticed some users in my server seem to lose their channels permissions when they log out / log back in.. one of my friend was on my server, disconnected for a minute and came back to find out he had no more permissions to move around..
Is there a known bug that causes this? In my logs, it seems like he’s connecting with a different ID every time.. He’s using the latest TS6 client which means he’s connected with myTeamspeam.. identities shouldn’t change.
Are they changing for new identities?
I don’t think they do.. they simply disconnect and reconnect.. could they be changing identity without knowing ? I believe changing identity involve going to the setting, doesn’t it?
I just reproduced it. If client has just channel group and has server group as default guest. It will get deleted from db after sometime like he has never connected.
That would make a lot of sense.. I’m mainly using channel groups on my TS6 server while I was using server groups on my old TS3 server, never seen that happen on my old server! !
Is this intended ?
This is actually intended behaviour as the user does not seem to be that important, if not assigned a sigle server group:
