I’m looking at deploying Teamspeak at my organisation, but we have a system in place similar to DeepFreeze, which doesn’t store user data on log out. I’m looking for a way to automate the user import / export process so I can export a user’s data to their secure file storage on logout, and the re-import it on login. Has anyone done anything like this before? Is it possible to script it?
Thanks
That probably won’t really be possible in TeamSpeak? Or how exactly do you mean connecting to the TS server itself or as a client?
Well, if it’s only about the TS server, I think that’s pretty unnecessary since the server is usually part of the organization anyway.
I have deployed an onsite TS3 server with no issues, I’m referring to roaming the user’s unique ID between different computers
All relevant data is in %appdata%\TS3Client and %appdata%/TeamSpeak for the TS3 and TS6 client respectively. Syncing these files should be sufficient.
