Background behind channels
I don’t know how do make that pictures (background) behind the channels.
please show me how.
I want to make it on my server too
:smiley: :smiley: :smiley: :smiley: :smiley:
pic
These are channel banners. To do this, you go to the respective channel to edit and can insert an image link via the pencil of the background area.
The following tool TS5 Channel Generator from @pitkes22 creates matching strips of an image.
It’s called channel banner. If you go to edit any channel you will see the option next to the channel topic. You must have the necessary permission “b_channel_modify_banner” in order to do that!
This option is only available in the new client.
@Cornelius opps, messe the permission name! Thanks for the clarification.
It‘s also important to have the b_channel_modify_banner permission.
Thank you so much :wink:
Does anyone know where I can find images to do this?
You can use any image you like and set them as a Channel banner. To span a banner across multiple Channels you can use this tool, to slice one image into multiple ones. TS5 Channel Image Generator
To set the banner right click the Channel → Edit → Click the Edit Icon in the gradient container → Insert the URL → Click the ticks to save the settings
TeamSpeak_GiM1poqEoU
If it does not show up, check that:
It’s not showing up for me!
Make sure right URL is set and is reachable,
And make sure this setting is activated in your client options.
Screenshot 2024-02-12 152221
Does anyone know where I can get this channel banner?
not the exact image
Zgc0fw7
On this Picture are you connected to a Official Public Community Server provided by TeamSpeak itself? If yes then maybe @SYOX have the Banner Image in this Case. :smiley:
yes, Official Public Community Server
Here you go, the original banner:
How should my URL look to add this to banner?
Is there a way just to make 1 banner for a spacer? I just want to make a spacer with a banner and below that spacer I want to create the channels.
Of cause, just only set the banner for one channel.
Thanks for the fast answer.
I tried it, but I just see 30% of the picture in the banner. I dont know why.
And is it possible to add a banner without text?
I don’t quite understand that. The banner is just an image that you choose. So choose an image without text, or do you perhaps mean the name of the spacer? If so, just call it [spacer999], for example.
Do you mean something like that?
I just have to say that even though the channel banner feature is ‘relatively’ simple, it makes a huge difference - to me, at least.
Inside the forum here, there are currently ‘constant’ comparisons with Discord, with new ideas popping up all the time about what it takes to become/remain competitive. Purely from a visual standpoint, I find the design options and clarity (for servers) offered by TeamSpeak ten times better than those offered by DC:
