How about giving the user a better time when creating a channel? Newer Users probably don’t know how to properly create spacers etc. A simple solution would be to add some new buttons into the context menu to create channels:
Next point: Remove the [spacer] when clicking on a Channel, you already see it below Type: Spacer
This create channel dialog is overloaded with a feature only a few Admins on server need at some point.
I don’t see this as something we should add to create dialog.
The second point makes the first one invalid.
Spacers do not exist!
A spacer is only a UI hack for channels where conditions must be met.
- Channel is permanent
- Channel has name [?Spacer#] in the beginning
You want a spacer to be a spacer and not a channel.
My honest opinion is that this has no chance to be added. At least not like this.
Only if the old way get’s replaced with a real spacer and not a channel. And in the past we had no reason to add such thing, when existing system could be used already
