Bookmark - Connect on Startup
On the desktop client - WIN/MacOS - i have the feature to auto connect when opening TeamSpeak.
This option is not available in the Mobile.app?
This is a Need to Have, please :slight_smile:
Maybe there is a workaround?
Using NetworkRadios with Android - and Teamspeak will be the perfect solution IF it’ could connect to the server on startup :slight_smile:
Have a nice day!
Android on the radio allow to open up the app at »boot« - but stille need to manually press the channel i wan’t to connect… I would really like a more bulletproof solution… Power > Press to Talk…
@MadsDaniel I have the same problem on ios, do you have a solution? I only know that you can launch the app through ts3server://, but you can’t automatically connect through ts3server://{ip address} like the windows version.
