When you start Teamspeak for the first time, you can see the Homebase features (which obviously should not be in it yet) (see pictures). If you then restart Ts, the Homebase feature disappears again
That’s normal. If you are trying to use any TS5 server as a homebase, you won’t be able to do that. If you want to setup your global messaging, you need to use the myTeamSpeak homebase.
thanks for your help. ![]()
