When I adjust the volume of some of my friends because it is too high or vice versa to save the setting I have to close and reopen ts5, if I don’t do this and client X disconnects and reconnects in the future I have to adjust it again
This works fine here on Beta 40.
We had such reports before(also with mute on user is reset) but could not reproduce this.
Version: 5.0.0-beta42
problem appears again
Version: 5.0.0-beta58
I’m having the same issue. Everytime i reopen the client. All volume settings for others reset.
Same problem with beta 58
We still can not reproduce this. Also asked in beta group and 4 first replies where the same.
You both could try following.
Close the client and make sure you know your myTS login data
Open path
%appdata%\TeamSpeak\Defaulton your Windows -
Rename the
settings.dbfile -
Start the client
Retry.
If it still does behave like before we need more steps to reproduce.
