It’s not a big bug, the problem is the appearance when you put two badges.
Homebase was not set
Homebase was set
Homebase was set
Happen even with set homebase mostly while relogging into other accounts
Yes it is the login and only happens when you stay on the account page after login.
That’s known and trivial
Also happens with 1 or 2 and 3 badges
It hadn’t happened to me before, so I thought it didn’t happen often
