so i tried to change my name From XprayDxD to kalebthefox but it always tells me that this includes invalide characters am i the only one with that problem or is that just normal nowadays?
If by âchanging your nameâ you mean changing it in TS5 client, then ummmâŚ
Itâs not possible right now.
nah i mean the one on myteamspeak.com
Thatâs basically the same thing.
Any forecast for launching this function?
No
It says that to a username that is random
Why this function is available if you canât use it?
soonâ˘
(donât take it in a sarcastically)
There are/were technical reasons we had to disable it and actually even to display a slightly wrong error message (I think thatâs what confuses users the most).
Hello!
I dont know if it is a real Bug but i cant change my TeamSpeak Username. Even if i type in âfewferighehgthâ it shows âInvalid username providedâ.
Thank you!
its currently deactivtated, the function.
Okay, thank you!
Hey,
Iâm trying to change my myTeamSpeak username, but if I want to change it there come a message âInvalid username providedâ and I had tryied with random names but every name is Invalid.
With best regards
Davis
This is currently disabled.
(my guess: because of problems with the matrix server for the new TS 5 client)
Oh, but thanks.
Hi, I wanted to know why I couldnât change the name on the teamspeak beta
Itâs currently not possible to change the name. In the Future may it will be possible to change your nickname.
Thank you for your patient.
What is the sense of the âchange usernameâ feature in ts5 if all i get is âinvalid username providedâ no matter what i enter?
Maybe you found a âBugâ
