That‘s no bug. It‘s currently disabled.
When are they going to enable it?
It’s not yet known when it will be possible to change your nickname again.
Hi!
I would like my myTeamSpeak username to be changed to ‘LeRflex’.
I have contacted Customer Service previously and was directed to post this request on the forum.
Thanks!
Changing the myTeamSpeak name is currently not possible.
oh ! okay tysm
its quite funny innit? for almost a year it hasnt been fixed
There is nothing to fix. We turned that off and still are in a closed beta state.
hey,
when i try to change my username in the settings menu then i get the error saying “invalid username provided” after pasting my pasting my password in the field.
i can log in with the same password on the websites
“The system to rename yourself is temporarily disabled.”
Hi, i found bug in TS5,
for some reason I can’t rename myself to TS5, I have the option to rename myself there, but every time I write anything there, it writes to me that it’s not allowed.
That is not a bug. The system to change the name is currently disabled. There is also no official date, when it is possible to change names again.
we must live with our poor choices apparently
moved by mod
Moin Moin warum kann ich meinen Benutzernamen nicht Ändern bei myTeamspeak ?!?!
Moin Moin why can’t I change my username with myTeamspeak ?!?!
Das ist derzeit deaktiviert.
Achso super … ist bekannt wielange das deaktiviert bleibt ?
Achso super … is known how long it remains deactivated?
ahh okay …
Super Danke für die Info
ah ok…
Great, thank you for the information
Hello, i did try to change my accountname, but its just yelling “critical error”
It‘s currently unavailable.
On the TS3 client, I want to change my username. Everytime I try it I get the error “Failed to change username” but it doesn’t tell me WHY it failed. If I can’t change my username is there a way to delete my TS account? Note, I don’t want to change my nickname, I want to change the actual username.
