Sorry to bother! Can the application of “MULTIPASS” test codes be compatible with other test codes?
I just applied the “MULTIPASS” test code to my master account, but I just remembered that I am still waiting for the beta program registration to pass, but I have been unable to check the registration status, can I enter the beta plan if this test code is applied?
Addition: I just saw the “Do not use master account” prompt, is there a way to exit “MULTIPASS”?
Don’t worry, it’s pretty much the same, at least technically. If there are additions to the manual signup, you will still be eligible for that.
