Dear People of Teamspeak,
since the last Updates from Teamspeak, I get sometimes the Error Cannot send a message at this time which has NOT something to do with the Permission System.
The problem is that I have enough Permission to send a message and it only works if someone is removing and adding me to the Server Group.
This error occurs sometimes but not every time on different Servers.
Seems like your client is not taking over the permissions you have on the server, as the client is not displaying any server/channel group icons for you either.
It is a permission issue.
Known bug: on fast connection the client does not get Channel and Server groups. Reconnect is required.
With the slow Connection, it works. But by autostart, it does not how you said.
Client b52 will fix this issue.
