Can't connect, please help
I accidentally set the modalquit mode for the server announcement, and now everyone can’t connect, how to modify this setting
[image]
Try this:
in terminal where you start the server
./ts3server_startscript.sh start virtualserver_hostmessage_mode=0
if I remember correctly, this will be the solution :slight_smile:
Or you can try it via the Server Query like:
login serveradmin XXXXXXXX
use 1
serveredit virtualserver_hostmessage_mode = 2 virtualserver_hostmessage = Welcome
I am using the server created by windows, where is this used
Is it this one? But he said I don’t have permission
[image]
QQ截图20220925171824
QQ截图20220925171907
Are you the Owner of this Server?
