Can't connect to TS servers with older Android versions
I saw the last few threads about problems with the recent app update. I waited for the update and today I got the latest 3.4.9, which should have fixed the app freezing, but it’s still not fixed. BTW. your date in changelog is in the future 09-Feb-2026 will be in 4 more days.
I tried to change to 48000, 44100, mic via music/phone mode, hands free (speaker) output, still nothing, cant connect to any server.
@MatisOne Can you please provide more information.
  • Android Version
  • Your device
  • Is it happening on any server?
  • Are you using a Bluetooth device?
  • a few screenshots from your settings would help to narrow it down.
I think its a problem with older Android versions? With android version 16 no problem.
But with a older Android version 13 its stucks.
Just want to chime in and say, that the voice.teamspeak.com server was offline today, until ~2 hours ago.
Also we’ve just published a new version for testing on the beta build. Available here or trough the Play Store directly. If you could quickly verify that it is still not working / now working would be great.
Good evening, I encountered the same situation as above: Android 14 and the app doesn’t work. At first, it was impossible to optimize the battery because the download itself was delayed. Then there was no connection. After that, the app asked me to close it because there was no response. I changed the purity, reinstalled it. Are there any solutions?
Sadly, the same issue remains in the new beta version.
Moving this back to the original topic…
We were able to reproduce this issue with an older Android device. We’re now doing some more analysis what exactly is causing this and once a new version is available we’ll post an update here.
Sorry for the issues with the latest updates, the App hasn’t been updated in a long time and has now received internal changes, which causes some things broke :melting_face:
Same here, works fine on pc but hangs with “wheel of death” when trying to connect to any server on android 12…meh…pls fix…thx
Just to give you all an update:
We’ve narrowed it down at which step the issue appears. And are now working on a fix.
We’ve just published a new version for testing on the beta build. Available here or trough the Play Store directly.
Please check and see if the issue is still present.
For me it’s fixed already!! Finally, and thanks!!
  • Android 10
  • Honor View 10
  • any server
  • Bluetooth is off
On first start after install:
if i try to login with TS credential:
if i try without login remain stuck on “loading items”.
if i restart app, it’s remain stuck on startup logo.
After deleting app file & cache i can log in, but remain stuck in “connecting”, cancel doesn’t work .
If i restart again, i can not see any bookmarks and if i try to connect to a public server ( or any other via new bookmark), the app crash.
Can you open the changelog and tell me which app version is installed? It is shown at the bottom of the changelog.
You can find it in the hamburger menu.
Play store version 320
You’ll need 332. That is the version with the fixes.
Like said, make sure that you are on the beta update branch:
Now its working (beta 3.4.9) on a Motorola Edge 20 lite (android version 13) Other phone Samsung with android version 16 and 3.4.8 no problems. Thank you.
Edit: But I see now (Recording frequency is 48000). I try now 44100 and also working!
GG’s working again android 12…
works fine, thanks @LeonMarcelHD :smiling_face_with_three_hearts:
