Channels sort
Hello, when I use ClientQuery and i run the command channellist i get the channel in a random order, someone have the formula to sort the channel by cid,pid,channel_order in order to get the exact order of the server channels?
Afaik and understand the query docs
This is not possible natively.
You could post process.
I really like CyberChef for this kinda work.
You can easily input, manipulate and output your data.
I was not able to sort the channels (not saying it is not possible) with this tool but maybe you can get an idea and try a little yourself.
This for example beatifies the output in a nice table.
While this would give you the table in csv syntax.
