I haven’t really found anything regarding this issue so far:
After running the client for more than a few days, I can switch channels a couple of times without audio cues (channel switched, etc.) before I can’t switch at all. At this stage, the client will not respond to any input (PTT, etc.) until I exit the client and restart, only to find my old self still sitting in the last channel I was able to move to. I will then have to kick the old client or wait until it has timed out.
It’s not a big hassle; honestly just a weird problem I’m seeing, and don’t know if anyone else has come across this issue.
Some extra information:
Win11 (22000.856)
TS (Beta 70)
Is this reproducible for you?
Are there any errors in the client log? > %LOCALAPPDATA%\TeamSpeak\Logs\Default
I haven’t tried reproducing it on purpose.
[2022-08-16 15:47:37.643] [info] Windows Audio Session - Device removed{0.0.0.00000000}.{c3a755e5-18d8-4ed3-a7de-f04152914021}
[2022-08-16 15:47:37.829] [info] Windows Audio Session - Device removed{0.0.1.00000000}.{144a40d9-0303-4d2d-bda3-36a9bc9301e0}
[2022-08-16 15:47:37.973] [info] Windows Audio Session - Device removed{0.0.0.00000000}.{c3a755e5-18d8-4ed3-a7de-f04152914021}
[2022-08-16 15:47:38.042] [info] Windows Audio Session - Device added: {0.0.0.00000000}.{c3a755e5-18d8-4ed3-a7de-f04152914021}
[2022-08-16 15:47:38.060] [info] Windows Audio Session - DEVICETYPE_PLAYBACK - Default device changed: {0.0.0.00000000}.{c3a755e5-18d8-4ed3-a7de-f04152914021}
[2022-08-16 15:47:38.133] [info] Initialized with 2 channels in 32bit, 48kHz. - Headphones (Soundcore Life Q30)
[2022-08-16 15:47:38.170] [info] Windows Audio Session - Device removed{0.0.1.00000000}.{144a40d9-0303-4d2d-bda3-36a9bc9301e0}
[2022-08-16 15:47:38.243] [info] Windows Audio Session - Device added: {0.0.1.00000000}.{144a40d9-0303-4d2d-bda3-36a9bc9301e0}
[2022-08-16 15:47:38.255] [info] Windows Audio Session - DEVICETYPE_CAPTURE - Default device changed: {0.0.1.00000000}.{144a40d9-0303-4d2d-bda3-36a9bc9301e0}
[2022-08-16 15:47:38.875] [info] Initialized with 1 channels in 32bit, 16kHz. - Headset (Soundcore Life Q30)
[2022-08-16 15:47:46.472] [info] Windows Audio Session - Device removed{0.0.1.00000000}.{144a40d9-0303-4d2d-bda3-36a9bc9301e0}
[2022-08-16 15:47:46.505] [info] Windows Audio Session - DEVICETYPE_CAPTURE - Default device changed: {0.0.1.00000000}.{0ac4716f-7c5f-49ce-b0ed-6c871241afbb}
[2022-08-16 15:47:46.547] [info] Windows Audio Session - Device removed{0.0.0.00000000}.{a81ddbfe-27ff-4afa-8b94-5d186062b200}
[2022-08-16 15:47:46.826] [info] Windows Audio Session - Device removed{0.0.0.00000000}.{a81ddbfe-27ff-4afa-8b94-5d186062b200}
[2022-08-16 15:47:46.826] [info] Windows Audio Session - DEVICETYPE_PLAYBACK - Default device changed: {0.0.0.00000000}.{ec5dfeae-868f-46ef-86c3-ae0b79b4944c}
[2022-08-16 15:47:46.827] [info] Windows Audio Session - Device removed{0.0.0.00000000}.{c3a755e5-18d8-4ed3-a7de-f04152914021}
[2022-08-16 15:47:46.869] [info] Windows Audio Session - Device removed{0.0.0.00000000}.{c3a755e5-18d8-4ed3-a7de-f04152914021}
[2022-08-16 15:47:46.870] [info] Windows Audio Session - DEVICETYPE_PLAYBACK - Default device changed: {0.0.0.00000000}.{ec5dfeae-868f-46ef-86c3-ae0b79b4944c}
[2022-08-16 15:47:50.475] [warning] Couldn't remove client from whisper whitelist.
[2022-08-16 15:47:50.475] [warning] Whisper Receive Manager: Couldn't remove client from whitelist. Client already left.
[2022-08-16 15:47:51.886] [error] [Playback] RenderDeviceContext callbackWaits2 wait exceeded 5 secs 258 - VoiceMeeter Input (VB-Audio VoiceMeeter VAIO)
[2022-08-16 15:47:51.886] [error] [Capture] CaptureDeviceContext callbackWaits2 wait exceeded 5 secs 258 - Microphone (2- AT2020USB+)
After this the error keeps going until I restart the client. Honestly didn’t check the logs first. Could definitely be a problem with Voicemeeter. I’ll have to try that without it.
It also gets flooded with this message:
[2022-08-17 13:14:08.623] [warning] Couldn't remove client from whisper whitelist.
[2022-08-17 13:14:08.623] [warning] Whisper Receive Manager: Couldn't remove client from whitelist. Client already left.
