today i started the ClientQuery plugin (version 1.5)(port 25639) and tried to use the help command. But it seems that the documentation has been removed with Teamspeak version 3.6.2 (error message: error id=1538 msg=invalid\sparameter).
Is there any other documentation or can someone upload the helpfile into this forum ?
The_chosen_one
Please download and install the plugin again.
Every needed file is still there (as you can see when you open the file with 7zip or other tools).
https://www.myteamspeak.com/addons/L2FkZG9ucy85NDNkZDgxNi03ZWYyLTQ4ZDctODJiOC1kNjBjM2I5YjEwYjM%3D
Haven’t tested in TS3 client and Query. Only have a tablet nearby at the moment.
Tested it and it’s just fine in latest versions (without any extra installation afterwards)
Thank you.
I helped myself and took the help files from another PC. If anyone needs them, please feel free to download them. ZIP file, contains a folder with text files.
Download: google Drive
SHA2-checksum: 5204367E5BFD0C0FA8A8D78DFF8909578EBDCE42CF6B00400677EE05CB1EE8F3
MD5-checksum: F9C6C9ED58E9C9B23F2A7E8695572366
CRC (32Bit) checksum: 2C91101F
Topic solved. Thanks Chris.
It’s a way but installing it again would’ve fixed it right away when files are missing in your folder(s).
