Community does not work / is not started
Sadly its not possible to change the Host Banner and Host Button Settings. Couple of permissions are not set or setable for Serveradmins. No Query Access aswell. You get a restricted down Server with the Community, for which you pay for… Meh :confused: somewhat dissapointing but we’ll test anyway and look forward for the Serverfiles ^^
{'status': 'DISPOSED', 'region': 'do-fra-1', 'creationTime': '2025-01-21 17:41:31.0', 'isLastServerStatusAvailable': True, 'serverPrivKeyAvailable': False, 'lastServerStatus': {'updated': '2025-01-22T23:18:52'}, 'disposalTime': '2025-01-22 23:18:52.0', 'isServerDisposing': False, 'isServerDisposed': False, 'isOnline': True, 'isServerSuspending': False, 'isServerAwakening': False, 'isServerSuspended': False}
What does disposed mean? How can we interpret that response? How can we understand what phase the team is in? On my server, last update is 24 hours ago. Last action is dispose. what does it mean? Please provide additional technical information.
I can create new communities now. My last community is still on suspended but I created a new one and it works fine! It took 3 days but its working for me right now!
I can create new communities now Can’t connect to this communitie pls fix
My old ones never worked so i dont care.
I created a new one and thats now working :slight_smile:
I suppose this is under the same umbrella of “obliterated communities”, but I attempted to create my own, my payment info was accepted, however, upon creation I was met with “Select Region” dropdown list, which in fact did not have a single region for me to select, thus effectively making it impossible to create the community, since selecting a region is mandatory. I have cancelled my subscription for now
Hey, why im still not able to create communities properly?
I created 4 Communities, 2 are suspended and 2 are invisible but the one i can see, are still “starting”. I can’t delete them also. Starting since 3 days btw.
Yeah, just subscribed, tried to create two communities, both which do not “start” and end up vanished, not even listed in suspended or anywhere… Any updates?
There is your Answer:
Mine started up fine, I just cant connect due to “could not resolve hostname”.
Can’t self host and can’t use a purchased server…
My community started, then I tried to click on Claim Community, I click on Open Link in popup and nothing happens.
My TS client is running in background.
I’m having the same issue.
I get the “Failed to establish connection to TeamSpeak server” error, and the reason says “failed connection initialization.” When I click “Claim Community” and then “Open Link” in the popup, nothing happens. My TeamSpeak client is running in the background, but it just doesn’t seem to work.
Has anyone found a solution or knows how to fix this? Any help would be appreciated!
Screenshot_1 - Kopya
cant connect to my rent server…
I bought TS6 community server 5 days ago but I couldn’t join my server even once, but the main problem is that I have no idea when it will start.
When I check the website right now, I see that fra2 servers are on sale but I can’t transfer my fra1 server to fra2, at least try to help. You start selling new community servers but old buyers can’t even get to their servers
Maybe try to delete the current one and set up a new one. It seelm like the old one is stuck in a loop.
‘’ permanently deleted in **30 days’’ in means I need to for 30 or I can immediately can create new one , u have any idea about it ?
I think you should be able to immediately create a new one. Other option would be to set the slots of this community to 1 and just use the remaining slots for a new one!
I cant delete or change slots either… Seems like i stuck on there Ahahaha
If thats the case please contact the teamspeak support, they will help you fix the problem!
They don’t, contacted them for the same problem 3 days ago, still stuck in the same position
