Hi everyone, i am new in making teamspeak themes, i just wanna know how can i copile my folder into a ts3_style. Any tips?
The following must be in your zip file:
Style folder:
- This includes all style files (.qss file and folder for your tpl and png’s)
package.ini
- Contents of the file:
code
Name = YourTemplateName
Type = Style
Author = YOURNAME
Version = 1.0
Platforms = win32, win64, linux_x86, linux_amd64, mac
Description = “ANY DESCRIPTION”
thank you for you fast reply. I have both. After that i zip it and i renameit with ts3_style instead of .zip no ?
I think you must rename the .zip Try it
i did that and it says that “Failed to extract Add-On:” and that it failed to extract the package.ini
Well, when I had fun with themes, I never had to compress anything into .zip. I just put every .qss file and folders (with additional files) named the same as these into themes folder.
But I used someone’s theme as a template, so yeah
Make sure that the folder structure is correct.
My.ts3_style
├ package.ini
└ styles
├ *.qss
└ MyStyleName [folder]
├ [potential sub folders]
└ *.tpl
