After connecting a server I get the following error message:
TeamSpeak 3 cannot write to the configuration file
This is the first time I get this message, before that it just simply crashed.
Any hints? Thanks!
Start TeamSpeak 3 as administrator and check that your folder is not read-only.
Your Windows user got no permissions to write into the settings.db.
And this is required or else you can not save any setting into settings.db.
To fix this you must ensure that your Windows user has access to the folder and write permissions on the settings.db
Note: This has nothing to do with any server.
Thank you for your response!!! We didn’t even found the file or folder linked…
C:\Users\Dell\AppData\Roaming\TS3Client\settings.db
Just open Windows key + r and type C:\Users\Dell\AppData\Roaming\TS3Client\
In that case there are no permissions to create the folder at all. This would trigger the same error.
Double check if path exists.
No, the path does not exist. System administrator rights are given…
The path from him is in the Screenshot.
(if this is the case)
The path in the screenshot does not exist… There is no Appdata folder created.
The path is now OK, the files are at the right place but the application still crashes…
Could you upload a crashdump file pls?
I can’t load the file here - which part would you like me to copy-paste or printscreen in?
Anything else we can do?
