Hi all,
Does anyone know how to disable / hide the tick on the default channel please?
Kind regards,
Shane
Hi all,
Kind regards,
Shane
If you change the default channel as spacer, i.e. put [spacer]
in front of the channel name, the icon would be gone.
I donβt know if there would be an alternative to a spacer channel.
