Detached screenshare window is stuck on main monitor and cannot be resized
In TeamSpeak 6, after popping out a screenshare into a separate window, the detached window becomes stuck on the primary monitor and is not movable at all. it can only be closed or re-attached back in to the client window.
with the default windows hotkeys (Win + Shift + Arrow Keys) the window can be moved to other screens tho. but for whatever reason, i can’t bring it to maximize/fullscreen on the monitor.
The client seems to hate the “Both” option for “Hide TeamSpeak in Taskbar” and a workaround is to use any of the options except that one. The popout window can be moved around if this option is changed.
Thanks for the report, we’ll look into that. I can confirm that the window can’t be moved when the setting is set to “Both” and “On Minimize”
TID: 2094
