Disconnects ping timeout
My teamspeak loses connection randomly, sometimes not for hours and than every 1 min. In my logbook I found this, which looks like the problem.
10-10-2024 13:41:49	TSDNS	Info	TSDNS queried unsuccessfully xxxxxxxxx
10-10-2024 13:41:49	TSDNS	Info	No TSDNS found
10-10-2024 13:41:49	TSDNS	Info	TSDNS queried unsuccessfully xxxxxxxxxx
10-10-2024 13:43:39	PktHandler	Info	Dropping client 5431 because of ping timeout 19 0 0
10-10-2024 13:43:39	SCHandler	Warning	Got command data while disconnected, dropping
10-10-2024 13:43:39	ClientUI	Info	Connect status: Disconnected
10-10-2024 13:43:39	ClientUI	Info	Connection lost, want autoreconnect = 1
10-10-2024 13:43:40	ClientUI	Info	Autoreconnecting
I have tried the following:
  1. disabled anti-virus/firewall to determine whether this blocks something. Did not help.
  2. check whether my internet disconnects at all, it does not.
I am connectied via cable, and therefore is not a wifi-connection issue.
Nobody else on our server has this problem and currently I am checking whether it also happens to me on different servers.
Any help or advice in the meanwhile will be appreciated.
Hello @Architekton69 and welcome to the TeamSpeak Forum.
Here are a few Suggestions you can try to solve your issue:
  • Your ping or packet loss to that server is to high.
  • Your firewall or security center does block the traffic to that server. Maybe your settings need to a change here?
  • Your router detects the traffic as spam or as an attack. Please check that there is nothing like this running.
  • You could try to disable such settings for testing or set your LAN Ip to DMZ ( Remove DMZ after testing!!! )
  • Maybe your W-Lan conenction is not that good? Try a Lan cable instead for testing.
  • The servers ping or packet loss is for your connection is to high.
  • The server does have more then 1 IP and the hoster did nothing yet, to bind one of his IP’s to his server.
