Is it possible to take a Teamspeak 3 Channel Name and import it to a discord channel and have it update as the channel name updates?
Well, Discord and Teamspeak don’t cooperate with each other and I don’t think that would be possible.
I don’t know if it’s the right thing you’re looking for, but you can try the following plugin
What is this?
TeamCord is a Teamspeak plugin which brings Discord and Teamspeak together. This means, you have the ability to create a connection/link between a Teamspeak and a Discord voice channel for cross voice communication. The only things you need is a discord account and this plugin installed for Teamspeak.
