External Client Viewer (e.g. as an OBS Overlay)
TS6ClientViewer: TeamSpeak 6 Client Viewer for Stream & Video Overlays
Level up your stream with TS6ClientViewer, a highly customizable external Client Viewer for TeamSpeak 6. Seamlessly integrate it with OBS, Streamlabs OBS, or any software that supports browser sources.
Key Features
  • Comprehensive Customization: Choose between displaying the entire server tree or the current channel. Choose which server to display, keep a specific or your own channel in view, and more!
  • Flexible Layout: Align the viewer to any corner of the source and nicely integrate it into your stream.
  • Granular Control: Fine-tune the viewer’s appearance with options to hide/show channel names, client statuses, specific client groups (talking only, local client, etc.), and spacer channels.
Getting Started
  1. Visit the Customization Page: Go to https://ts5viewer.endercentral.eu.
  2. Accept Permission: In your TeamSpeak 5/6 client, grant permission to the Client Viewer when prompted in Notifications.
  3. Preview & Adjust: The customization interface allows you to preview your changes and fine-tune settings as desired.
  4. Copy Export URL: Once satisfied, copy the Export URL generated by the interface.
  5. Integration: Create a new Browser Source in OBS, Streamlabs OBS or any other streaming/recording software and paste the Export URL into the URL input field.
Closing Words
I created this Viewer as I needed an Overlay for my Stream. I originally used DerTyp7’s Overlay but due to the shortcomings it had (had to write custom css to align it to the right, it often broke down, 2-level-deep sub-channels didn’t work, needed to reload it a lot), I wanted to create my own. I wanted to make it as customizable as possible to cover a large amount of use-cases for such an Overlay.
If you have any suggestions or encounter any issues, feel free to let me know.
Github
If you want to stay up-to-date, visit the Project’s Github Page for Update Notes:
Looks very good.
I like the idea/features you brought in.
Especially that you have the ability to display the entire server tree.
looks great!!
Nice,can i use it for Rainmeter :question:
I’m not familiar with Rainmeter but the PluginWebView looks like it’s what you’d need to make this work with Rainmeter.
smiley_emoticons_danke_ATDE
Great Work!
