I think some more settings could / should be synced using myTS.
Mainly I would like to see the client language synced.
Not a fan of this request.
In priority the client should take the system language as long it wasn’t set otherwise on that system.
So what about this:
You introduce a new option in the drop-down: System
This would fix multiple things:
- You could synchronize the settings while allowing the users to overwrite it.
- Currently the system setting is only detected once. That means if I change my system language, TeamSpeak will remain outdated. Also if my system language is not yet supported TeamSpeak won’t automatically switch once the language is added.
Nope.
As long user did not touch language settings (and stored these in the preferences.json) this is checked on each start.
See above.
Okay, then I was mistaken.
This however would still not allow the user to switch back to the system-selected one after they picked one.
Let’s say my language is not yet supported so the client falls back to English. I don’t really speak English but another language that is implemented, so I switch to that. If now my real language gets implemented the client won’t switch to it as I selected another one previously.
As we did discuss in voice (for the reader(s) here):
In that case you would not get the new language, because you did set it before and it would sync the old setting to your client.
Another idea:
- sync frequently used emojis
