Hello, I’m trying to install the TS Gateway Commander 4.0.2 plugin on TeamSpeak Client 3.6.2, but I’m encountering an error (screenshot attached). Could you help me? Thank you very much!!
I assume that you have a bad version of the plugin and that it is not compatible with your version. Can you share your log?
By the way, I found this post on google.
TS3Gateway[LINK].dll plugin is required !!Attention!!
Plugin must be in your Teamspeak 3 main directory 32BIT (Important Teamspeak 3 32BIT not 64Bit) Teamspeak 3 (RECOMMENDATION) installed
under (Save in installation folder)
: C:\Users(your Windows user name)\AppData\Roaming\TeamSpeak 3 ClientCB\config\plugins
Then open Teamspeak Client and activate the plugin under Settings > Extensions!
Thank you! I’ve made several attempts but haven’t had any success. It seems that the plugin is no longer compatible with this version of TS3. If anyone has a compatible version, I would greatly appreciate it. Alternatively, I’m open to suggestions for another plugin with the same functionality. Thank you!
@Mms77svq
Maybe i have found what you are looking for:
Working fine for me here on Client 3.6.2
Download Link: Click here to download the TS3-GatewayPTT Plugin
Please give me Feedback if its working for you. ![]()
Wow amazing it works fine!! thank you so much
You don’t know how happy you make me!!
Nice to hear and thanks for the Feedback. ![]()
Welcome to TeamSpeak ![]()
