I’ve been experiencing a very specific (and extremely annoying) bug with the TS6 beta overlay for nearly a year now.
What happens:
- When launching/restoring TS6 from minimized, a solid grey rectangle appears first (the placeholder/animation canvas).
- The actual UI then slides in from the taskbar area on top of it.
- On minimize or close, the UI disappears correctly, but the grey placeholder box is not removed from the DWM compositor. It stays permanently visible on the desktop as a ghost rectangle.
Findings:
- This only occurs when actually minimizing or fully closing TeamSpeak.
- If I do not close, but only minimize TS6, simply unminimizing again makes the grey box disappear normally.
- It is very sporadic (happens maybe once every few days/weeks), but has been reproducible on my system for almost a year across multiple beta versions.
- Normal fixes do not work:
- Restarting TS6 processes
- Restarting explorer.exe
- Win+Ctrl+Shift+B (full graphics driver reset)
- Toggling overlay settings, hardware acceleration, etc.
Workaround:
Killing the Desktop Window Manager with taskkill /f /im dwm.exe (or signing out and back in of Windows) instantly clears it. This proves it’s a DWM surface that was never properly destroyed.
This feels like the same “grey placeholder hack” you’re using to prevent transparency/flicker during the slide-in animation. The destruction path on close/minimize isn’t 100% reliable.
Thanks!
