creating a new password error
old password is also an error
I want to connect this bot
connecting...
18:16:31.385 [[TeamSpeak-3-Java-API] SocketReader] DEBUG com.github.theholywaffle.teamspeak3.SocketReader - TS3 command error: {msg=connection failed, you are banned, extra_msg=you may retry in 393 seconds, id=3329}
18:16:31.398 [[TeamSpeak-3-Java-API] SocketReader] ERROR com.github.theholywaffle.teamspeak3.SocketReader - Connection closed by the server.
Exception in thread "main" java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.springframework.boot.loader.MainMethodRunner.run(MainMethodRunner.java:48)
at org.springframework.boot.loader.Launcher.launch(Launcher.java:87)
at org.springframework.boot.loader.Launcher.launch(Launcher.java:51)
at org.springframework.boot.loader.JarLauncher.main(JarLauncher.java:52)
Caused by: com.github.theholywaffle.teamspeak3.api.exception.TS3CommandFailedException: A "login" command returned with a server error.
>> connection failed, you are banned (ID 3329): you may retry in 393 seconds
at com.github.theholywaffle.teamspeak3.api.CommandFuture.checkForFailure(CommandFuture.java:415)
at com.github.theholywaffle.teamspeak3.api.CommandFuture.getUninterruptibly(CommandFuture.java:356)
at com.github.theholywaffle.teamspeak3.TS3Api.login(TS3Api.java:3000)
at de.lufen.TeamspeakBot.connect(TeamspeakBot.java:248)
at de.lufen.TeamspeakBot.main(TeamspeakBot.java:105)
... 8 more
18:16:31.403 [pool-1-thread-1] ERROR com.github.theholywaffle.teamspeak3.api.reconnect.DisconnectingConnectionHandler - [Connection] Disconnected from TS3 server
Then you should disable the flood protection for the bot so it can operate normally. b_client_ignore_antiflood (set the permission temporarily for guests, then give the bot a specific bot group and remove the permission from the guests) // or give the bot client permission
connecting...
19:05:51.754 [[TeamSpeak-3-Java-API] SocketReader] DEBUG com.github.theholywaffle.teamspeak3.SocketReader - TS3 command error: {msg=connection failed, you are banned, extra_msg=you may retry in 458 seconds, id=3329}
19:05:51.765 [[TeamSpeak-3-Java-API] SocketReader] ERROR com.github.theholywaffle.teamspeak3.SocketReader - Connection closed by the server.
19:05:51.768 [pool-1-thread-2] ERROR com.github.theholywaffle.teamspeak3.api.reconnect.DisconnectingConnectionHandler - [Connection] Disconnected from TS3 server
>> connection failed, you are banned (ID 3329): you may retry in 458 seconds
... 8 more
